Creating a V2 PCB
A project log for Over-engineered LED strip controller
Way too much stuff to light my garage MY way.
wjcarpenterWJCarpenter 09/02/2020 at 22:300 Comments
I decided to create another revision of the PCB to correct the various mistakes in the first round.
The original board dimension was about 94mm x 65mm. I did the layout as compactly as reasonably possible since I planned to house the circuit in a standard US electrical box. That compactness led directly to some of the problems I later encountered. I now know that the box I will use is 110mm x 190mm (minus some corner cut-outs). Since the inexpensive PCB fab houses typically have special pricing for prototype runs of 100mm x 100mm or smaller, I opted to spread things out and use the complete 100mm x 100mm for the layout.
The new board layout is in the project: https://upverter.com/design/wjcarpenter/oelscv2/. The schema also has minor updates.
Besides the more relaxed layout, the revised design has:
