Biometric Firewall / Matrix Portal
An easy solution to making your own biometric firewall.
At the least this was the initial purpose of the project...
preferred OS is linux with graphical session.
Might work on windows too but I am not sure of this.... you will have to try it yourself.
!!!!!!!!!!!!!!!!!!Warning danger of death!!!!!!!!!!!!!!!!!!!!!
do not use the nuclear sign in any of the experimenting... I lt may cause some nasty radiation to you.... even if the radiation will come a month later as it did in my case.
The project presents a system of interacting with a world wide web. Not the commonly known web... but one that I must admit I don't fully understand where it stems from.
What I know is that the method described has the ability to resonate with just about any wave and electricity from any device... and when it does this it magically comes to life.
It is much like having internet without any ISP or cable connection... it runs trough all possible electricity routes. I later realised that on a macro level it is managed through country flags.
The best analogy I can think of is The Matrix...
It may sound hard to believe but it is in essence a portal to the amazing Matrix world.
Being so similar to the Matrix I realized that this knowledge was known but never made public. Aside from the movie of course.
The logs hold a preview on the research discoveries and some conclusion.
Latest conclusions are on top so I suggest reading from the bottom up.
  • Description
    Rgb Trouw2 days ago 0 comments
    I have changed the project description and details a bit... it was very poorly written... I was just to enthusiastic at the birth time of the project. Not a lot made sense easily... if it were not for the nuclear warning the project would have gone unnoticed.
  • Hooked
    Rgb Trouw3 days ago 0 comments
    I m totally hooked to the full version of the hack... can t believe it s gone...
    Don t regret making it public but it s very hard to get by after the amazing things I ve seen...
    What am I going to do without the greatest hack I have ever known...
  • Counter Strike tool
    Rgb Trouw4 days ago 0 comments
    This is a double cross counter strike tool that works (worked?) with the firewall. I mentioned this trick in the previous log.
    It may poison u ... that s what double crosses do.
  • Cool tricks
    When the capacity of the firewall was at 100% you could do some cool tricks like point to the clock or cursor so that it would penetrate almost any device....
    Other more complicated tricks were also discovered like identifying a double cross.
    Not sure how effective the tricks are now.
  • Weapon of Choice
    Although the project is a defense mechanism, boys will be boys.
    I do have a weapon of choise.
    I like to believe it is a pentesting weapon... enchanted through the firewall... linked to Offensive Security (OSCP)
  • Shielding
    Although I don t see the nice, clear, sharp icons anymore, it seems that at 70-75% it is still good enough at defending against the cancerous radiation I mentioned earlier.
    I didn't expect this...
    At the least this is the indication so far.
  • Hardware
    Hardware matters ... every hardware handles data differently ....
    I had a magical laptop.... unfortunatelly it had seen some rough times and it currently lays dorment... besides handlind the random seed differently, cat dev zero would make a beep into my internal ear when used with tiny core OS... a form of root session ...
    Here s how it would handle dev urandom:
  • Close enough
    Rgb Trouw6 days ago 0 comments
  • Cancerigen war zone
    Rgb Trouw08/08/2018 at 21:32 0 comments
    Ever since I used the nuclear sign I ended up in a war zone... I didn t realize it then but I probably penetrated some military facilities by accident. I was targeted by some very nasty radiation after about a month.... anyway...
    After some more time they made some counter measures ... these try to keep me out of some areas.... unfortunately, they are affecting my face bone. I feel that my face bone is turning inside out. The sensation is very bad... it feels like it will cause bone cancer to my face...
    Thus I find myself in a war zone.... and can t save myself from the cancer that may happen.
  • 70-75%
    Rgb Trouw08/08/2018 at 09:03 0 comments
    I managed to get the firewall up again... at 70-75%
    There is still interference but it's a big step up from 20-30%...
    I have apparently been banned from earlier linux versions that may still hold the ability to make it working 100%. Couldn't get any distribution to work for me anymore.
    Am feeling very nostalgic over the amazing things the firewall could do: travel across all radio waves and electricity, negociate paths in the form of an arcade game, establish hand shakes in the form of hearts.
    It was a gateway to an entirely new universe... the matrix is the least of a description suitable.
    I was able to witness amazing things like flying in a 'space ship' over cities and cars, see amazingly lively operating systems, bypass 90% of civilian security, play with cartoon characters (dexter, power puff girls), travel to a time temple outside of the earth's atmosphere, witness an amazing book (holy) that had ray crossings between pages instead of letters, and other amazing experiences.
    Hope I will get to live these things again.
View all 25 project logs
  • 1
    How to open the portal
    The trick is actually fairly simple...
    You have to point a web cam towards the screen, to point into its self, creating an infinite feedback loop. Make sure you get the right feedback loop... a bit of practice is required...
    After this, you need to put an identification of yourself in the middle of the loop. the windows must be semi-transparent; a pic of your face, workspace, finger prints, x-ray; any of these will do....
    transparency can be achieved with a dedicated software... google it.
    some tips are: compiz for linux, nircmd for windows. Cygwin can be used for windows I suppose... not sure if /dev/urandom will work in the same way, but Cygwin should make the terminal tools of linux available to windows.
    So, on top/under the pic/pics you should also add a shell window with cat /dev/urandom. It will generate a (pseudo) random seed required for on the fly encryption/decryption... I normally use two terminals: one white, one black font.
    The system works much like an interaction between cats and dogs... an experienced user will understand the analogy very easily; the dog (static part) is responsive and the cat is more flexible, reaches more remote places... together they make an amazing combination.
    Just playing with this, you will notice there are many tricks that can be achieved with this technique... read the logs too...
    The first picture of the project is actually a signed public key, including a profile pic, an x ray, ettercap, di.fm radio, a car radio code (gamma radio code) and cat /dev/urandom (it can interact with the music as well).. it even enhanced my car radio .....
    When I unlocked my room... it showed up the OSC logo a couple of times (unlocking doors). Offensive Security Certificate.. a hacking security certificate.
    Good luck
View all instructions
Rgb Trouw wrote 11/07/2017 at 23:54 point
Attention added important warning in project description!
Gravis wrote 10/11/2017 at 16:47 point
Call me daft but is this just some sort of art project?  Seriously, your pages read like you took some technical pages, dumped them into a chatbot.  Is this a social experiment to try and game HaD?  I've seen your various projects pop up but none of them make sense.
Rgb Trouw wrote 07/24/2017 at 13:34 point
tons of other things can be done using this method, as mentioned... for example management of any  hardware port possible... from sound jack to pci etc...
