As I put the inner surfaces into the rest of the cube I recognized that the top edge didn't matched perfectly.
First I thought about to just rasp it away, but that would be too much work and I had an better idea:
I think this solution is even better than the first plan, because the space between the green and the grey part is perfect for connectors for the controller and power supply.
sisam
