New Cherry MX Controllerboards and a first Case
A project log for Social Gaming Cube
A Pixel-Gamingdevice. Play together, not against each other.
sisamsisam 10/19/2014 at 11:410 Comments
The previous days I built two new Cherry MX controllerboards. At the first one I minimized the distance between the switches.
Heres a foto of the second one:
I also cut the parts for the cases of both new controllerboards out of a 3mm MDF board.
parts for case for board2 ( parts for case for board1 are similar )
And I built the case for board1 :
First I glued together this two parts :
Next I milled these hollows into the parts, to give the springs on the USB connector space to let them do what they do.
Then I glued some small card pieces on the bottom of the board to have a flat contact area.
Next I glued the board and the USB connector into the bottom part of the case, and fixed the wires with some hot glue.
To hold the connector in place I used a piece of a 3mm MDF, which I put under the connector.
Then I glued the top of the case on it.
