This robot counts with a multikit PCB that allows it to be programed with an Arduino Uno or a STM32 Nucleo. The board also allow the connection with some peripherals, like ESP8266, Ultrassonic Range Module and MPU9255 inertial unit.
Future advances includes a neural net and a CPG to generate the gait pattern.
They are shaking because they are working in 8 Volts when the maximum voltage is 7.2V huahuahua
This because 7.2V not had guaranted sufficient torch to the hexapod works :P
