Order PCB and solder parts on the board
A project log for Veterobot
3D-printable robotics vehicle with bunch of sensors for autonomous drive and remote control
andreynechandreynech 07/24/2017 at 09:570 Comments
The whole set of Eagle files (including libraries designed with EAGLE
6.3 Lite) to ordert the PCB is available in veter-cap
repository
. For our boards, we are currently using services from PCB-POOL. You might consider different PCB manufacturer depending on you location.
