Quattro parts.pdfHere is the file for the lasercutting. All the parts are here, all you need to do is laser cut them.Adobe Portable Document Format - 10.37 kB - 07/19/2017 at 13:53 |
leg_init.inoQuattro's legs need to start at their "initial position". To do this run the servo motors with this program and then set the legs to their correct positions.ino - 456.00 bytes - 07/19/2017 at 13:53 |
Quattro_test.inoBetter run this on a cup as a support. Quatro should before it's gait.ino - 20.25 kB - 07/19/2017 at 13:53 |
quattro_ik_pr.inoThis is infact very complex. Developed with the mathematics from Inverse Kinematics Quattro can now do pushups!ino - 3.60 kB - 07/19/2017 at 13:53 |
quattro_add_feat.inoThis code is with the added on obstacle avoiding feature. Quattro with the ultrasonic sensor will navigate in an environment without knocking into objects.ino - 20.63 kB - 07/19/2017 at 13:53 |
