Screwless (snap-in) servo mount
A project log for Versatile Educational 2WD Robot
This is an affordable Open Source 2WD robot chassis that is 3D printable and can be used to teach robotics and interfacing sensors.
DasakiDasaki 07/22/2017 at 10:512 Comments
One of the goal of the design is to reduce the amount of "vitamins" or buyed parts as much as possible, and at the same time to simplify the assembly.
So I modified the main chassis piece some to allow to snap in the wheel's servo motors, hoping they would hold in place firmly. The results are great, four less screws and motors quickly intalled.
deʃhipu wrote 07/22/2017 at 16:23 point
Then again, you get those screws with the servos, but I guess now you can use them somewhere else.
Dasaki wrote 07/23/2017 at 12:36 point
You are rigth, but now it is faster to attach/detach the servos. I've also noticed those screws are quite weak and tend to wear off. I left the holes anyway, in case someone wants to use the screws them anyway :)
