Schematics and detailed description
A project log for FAR
Fixed-rate Asynchronous Receiver. Extremely simple asynchronous serial input to parallel data output converter.
filipFilip 12/27/2014 at 22:430 Comments
I've added the schematics and detailed function description. I'll also add the waveform details and timing adjustment instructions - unfortunately an oscilloscope is needed to exactly match the serial port TxD, byte and bit timers. I hope that the need for oscilloscope can be eliminated by adding some LEDs and using software to feed special calibration patterns to the serial port.
