First baby steps
A project log for Dogbot
A quadrupedal walking robot
charles-galambosCharles Galambos • 07/09/2018 at 15:10•8 Comments
We've been trying some simple gaits animations to prove the robot can walk independently.  These run through a fixed set of movements without any feedback, this is the first one that worked so there is a huge room for improvement.  It falls over in the end of the video because of a problem with one of the motor controllers, it shouldn't take too long to track down and sort out.
Ulysse wrote 07/10/2018 at 20:55 • point
excellent  !
Charles Galambos wrote 07/11/2018 at 09:21 • point
Thanks!
Reginald Sourn wrote 07/10/2018 at 08:26 • point
Congrat!! very cool!
Thank you, hopefully more coming soon!
deʃhipu wrote 07/09/2018 at 16:09 • point
That doesn't look too good. Is it power problems?
Charles Galambos wrote 07/09/2018 at 17:07 • point
We had it walking for about 5 minutes before the video. At the end one of the motor controllers cut out, I am adding more diagnostics to work out why.
Charles Galambos wrote 07/10/2018 at 07:09 • point
The legs have some give in them, which wasn't accounted for properly the first time it was walking. With a bit of tuning it will be much better.
deʃhipu wrote 07/10/2018 at 07:58 • point
Oh, I see, I wasn't sure if it's the legs or the motors. This is good news, because in the worst case you can just make the legs more rigid.
