Rest assembly
A project log for Tool Switching - Multi Extrusion
A scaleable approach to multi extrusion, easy to adopt in most CoreXY/H-Bot printer designs.
rolmierolmie 07/23/2017 at 15:280 Comments
Required parts
ToDo's
A parametric design for OpenSCAD with arbitrary amount of positions will be available soon.
Assembly should be pretty self explanatory, the distance between the screw holes is 60mm.
Adjust the height of the rest such that it matches the height of the carriage over the whole distance.
