No real big changes in the software, but I took this video of the oscilloscope measuring the voltage across a resistor (and one current limiting resistor) while it goes through a Pulse Width Modulated dimmer sequence. Edges are looking sharp and the noise on the pins when they're floating is relatively low so I'm pretty happy.
endevor100
