The demonstrator goes portable !
A project log for Numitron Hexadecimal display module
Another hexadecimal display, this one is sans transistor for the extra vintage touch, and uses only Soviet-era parts
Yann Guidon / YGDESYann Guidon / YGDES 11/29/2017 at 13:290 Comments
I'm currently traveling in France and showing the module to other hackers and others !
However I've always used the demo board with my lab PSU so I need a cordless, portable power supply. I designed the module to accommodate 6V, or 4× alcaline cells, instead of 2×3.3V.
Just before leaving, I had a bad surprise : the circuit draws so much that AA batteries simply can't supply enough current. The device almost shuts down when buttons are pressed. With the lab PSU, I saw that it wouldn't work well at 5.9 or 5.8V and the AA batteries are too weak...
I arrived in Toulouse to visit @VDagrain, who loves that kind of hack, so I bought four C-type batteries, and visited "Le comptoir du Languedoc" to buy a suitable holder. Then, we visited the Artilect hacklab to solder that together.
(thanks Alexis !)
There was a bad contact in the battery holder but now it works nicely ! It's more bulky but the stunned gaze of people is really worth it :-D
Thank you Wanda ;-)
