Control and testing
A project log for Upgrading a Wilfa coffee grinder
Adding custom grinding presets to a Wilfa grinder, presented on a small oled display
bjarkethomsen1bjarkethomsen1 08/05/2017 at 20:511 Comment
To control interface is consisting of four main parts:
The encoder is used to select the different presets. As of now, there are two presets for aeropress and 7 for drip coffee. A curcuit from a mobile charger is providing supply voltage to the arduino from mains.
I had some problems with noice on the encoder signal. I used two 0.1uf caps and 10k resistors to do a hardware debounce, which worked great.
Franken-grinderCalibrating rate of ground coffee
I needed to figure out the rate of coffee ground pr second. To do this i simply grind for a specified time interval and measure the mass of ground coffee. Calculating backwards i get a rate of:
Now it is easy to convert the amount of coffee from grams to seconds of grinding.
Further work:
Mark wrote 04/01/2024 at 02:51 point
Possible you can share the partlist you used?
