#15 - Dpad fine tuning
A project log for Game-o-Tron Mini
A roughly credit card sized gaming handheld
david-boucherDavid Boucher 10/28/2017 at 14:140 Comments
As mentioned in the last log, I had a problem with the Dpad, where pressing one of the directions would in some cases trigger one of the adjacent directions, so pressing up might unintentionally get you left or right too. To fix this, I've added recesses to the bottom of the Dpad so that there is not enough pressure applied to the adjacent directions to trigger them, unless you deliberately press a diagonal.
I've also fixed the other issue that I mentioned regarding the size and positioning of the hole for the screen, so what should be the final, final, case front prototype is printing as I speak.
