AD8313 1MHZ to 6GHZ Detector
this project will show you how to make wide rage frequency Detector
single chip, low cost, fast and Adjustable
AD8313, LM3914 are ICs, that we need to run this project,
at first check schematic, ad8313 is tiny chip should use it carefully, if you are going to run project need smd to dip adapter as photo, of using circuit same me, would be much better. LM3914 is VU meter and connect to AD8313 over 4.7Ohm resistor.
PCB file will upload shortly, green pcb and normal pcb both have and working properly excellent.
to test wacth video
Thanks
Portable Network Graphics (PNG) - 2.23 MB - 07/25/2017 at 21:34
Preview
Download
Portable Network Graphics (PNG) - 1.18 MB - 07/25/2017 at 21:33
Preview
Download
Portable Network Graphics (PNG) - 1.75 MB - 07/25/2017 at 21:33
Preview
Download
Portable Network Graphics (PNG) - 1.14 MB - 07/25/2017 at 21:33
Preview
Download
MPEG-4 Video - 8.54 MB - 07/25/2017 at 21:33
Download
View all 20 files
