Flashing Light Prize (6) Arduino 101 Break Up
Parting is Such Sweet Elation
Parting is such sweet elation.
Elevation change per 0.15 meters (0.5 foot) measured by BMP180 triggers relay state.
Good riddance, Arduino 101. May your gibberish never stain my IDE again.
Notation(s)
1. Project worked to perfection--right up until the balloons were purchased. After having not acquired enough balloons (12) for lift, a stripping down of materials and conversion to a lighter 12 volt battery resulted in an accidental overload and in brief - kaput! Secondary to this, let it be known that filming string hung peripherals and balloon flight at night with low budget production is as impractical as this whole venture.
2. 1 liter of Helium lifts 1 gram. 12" latex balloon volume is 15L. Horse shit!
Archive
https://hackaday.io/project/26130-flashing-light-prize-6-arduino-101-break-up
http://flashinglightprize.com
  • 1 × Arduino 101
  • 1 × TIP120
  • 1 × 2.2K Resistor
  • 1 × 5V Bulb That Hates Solder
  • 2 × 9V Battery
View all 7 components
  • Arduino Skyetch
    Vije Miller08/01/2017 at 00:20 0 comments
    // Flashing Light Prize (6) Arduino 101 Break Up
    // BMP180 Code by Sparkfun
    // VijeMiller
    #include <SFE_BMP180.h>
    #include <Wire.h>
    // BMP180
    SFE_BMP180 pressure;
    double base;
    // States
    int last = 0;
    int up = 0;
    int state = 0;
    // TIP120
    int light = 7;
    void setup()
      Serial.begin(9600);
      pinMode(light, OUTPUT);
      digitalWrite(light, LOW);
      // BMP180 Working?
      if (pressure.begin())
        Serial.println("BMP180 init success");
      else  {
        Serial.println("BMP180 init fail (disconnected?)\n\n");
        while (1);
      // Create Base Line
      base = getPressure();
      Serial.print("Base Line Pressure: ");
      Serial.print(base);
      Serial.println(" mb");
      delay(2000);
    void loop()
      double a, P;
      // Get Pressure
      P = getPressure();
      // Different Between Base and New
      a = pressure.altitude(P, base);
      Serial.print(a * 3.28084, 1);
      Serial.println(" feet");
      // Higher by 0.5 Feet or More?
      if (a >= up) {
        if (state == 0) {
          digitalWrite(light, HIGH);
          state = 1;
        } else if (state == 1) {
          state = 0;
      // Add 0.5 Feet
      // Store Last
      up = a + 0.1524;
      delay(500);
    double getPressure()
      char status;
      double T, P, p0, a;
      status = pressure.startTemperature();
      if (status != 0)
        delay(status);
        status = pressure.getTemperature(T);
        if (status != 0)
          status = pressure.startPressure(3);
          if (status != 0)
            delay(status);
            status = pressure.getPressure(P, T);
            if (status != 0)
              return (P);
  • Kid Tested, Mother Approved
    Vije Miller07/26/2017 at 23:25 0 comments
    This project will require hard wiring. Tested with bread, no butter.
View all 2 project logs
  • 1
    Frizziness
View all instructions
