New Filter Design
A project log for Honda OBD1 Digital Tachometer
In this project I'm building a digital tachometer for 90's Hondas.
nigelNigel 11/03/2014 at 05:440 Comments
I've found a new, and hopefully more reliable and robust method of filtering the input signal from the tach. It uses an op amp in an inverting summing amplifier configuration. Next step is to order parts and breadboard it. Thanks for reading!
