Update #9: Final PCB
A project log for PiPod
Raspberry Pi zero portable music player
brambram 08/02/2018 at 17:320 Comments
I have received and assembled the final version of the PiPod PCB in this version I replaced the CS4344 DAC with the PCM5102A, added the ADS1115 ADC to measure battery voltage and detect if it is charging and I redid the boost converter layout. I have also submitted the design of this board to the second PCB design challenge on PCBWay.
Assembly
I started assembling the bottom part of the board and used some 3D printed standoffs to easily assemble the top part. The information to assemble one of these board can be found on Github.
