Update #11 quick update on new image and case version
A project log for PiPod
Raspberry Pi zero portable music player
brambram 09/20/2018 at 20:530 Comments
Disc image
There is a new version of the PiPod image available right here, this version has a few improvements:
New case files
The next PiPod board will have a thicker PCB to make the device more rigid. The STL files for the case are already available on Thingiverse. These files are named: Top_1.6mm_.stl and Bttom_1.6mm_.stl. There's also a new frame for the inside available this frame is more rigid and fits the 1.6mm and 0.6mm board.
