Initial PlayerUI release
I pushed the initial release of the interface I am writing for my music player, it is functional but there is still a long todo list.
If all the modules are installed you can run __init__.py this will load the main screen from there you can navigate to the Settings and update the library this will make the program look for all .MP3 files in the "Music" folder and save the metadata to a .csv file for a quick lookup.
Main screen
The main screen has all the controls on it and the information of the current song.
Menu
Music submenu
updated case
I have also made a few changes to the case design, here they are:
- The screw holes are now countersunk
- There are little lids so the middle button won't completely rotate
- The SD card hole is a little bigger
- The clip for the audio connector is a bit thinner to be more flexible
- The slide switch inserts from the back instead of the front
