Just finished my Coil Winder project
A project log for Coil Winding jig with foot pedal control
This is my coil winding jig project for doing inductors transformers and anything else you can think of
razvan-caldararuRazvan Caldararu 08/15/2017 at 17:410 Comments
  So, I've finished putting together the code for my coil winding jig. I've added  the code for the optical counter and threw in a reset switch, that resets the turns count.
The display is your run of the mill  16x2 LCD.
The Arduino code and also the other files for this build are in my GitHub repository. Also, for a full write-up, you can check out my blog page for this project.
Here's a short demo video of the winder. Enjoy!
