Prelimary parts list
A project log for Actobotics CNC Mill
I'm working on a light-duty CNC mill that I'd custom-build out of Actobotics parts.
john-baichtalJohn Baichtal 08/08/2017 at 22:460 Comments
This is a partial list of Actobotics parts used in this project:
Y-AXIS
1x 12” aluminum channel, P/N 585454
2x 3.75” aluminum channel, P/N 585443
4x 90-deg angle brackets, P/N 585532
4x 90-deg pattern mounts, P/N 585494
1x 12” d-shafting, P/N 634094
1x 1/4” to 4mm clamping shaft coupler, P/N 625049
1x aluminum set screw collar, P/N 9946K11
1x 1/4” ID x 1/2” OD flanged ball bearing 2-pack, P/N 535198
1x 6.25” x 7.25” ABS sheet, 1/4”, P/N ABS250-625-725
4x large square screw plates, P/N 585430
6x small square screw plates, P/N 585478
2x channel connector plate 2-packs, P/N 545532
3x 6-32 zinc-plated socket head screw 25-packs P/N 632114
20x 6-32 black-oxide socket head screws, P/N 91251A148Y-
X-AXIS
2x 8mmx250mm shafting P/N 634312
4x 8mm set screw hubs, P/N 545636
1x 2” d-shaft, P/N 634068
1x 3” d-shaft, P/N 634078
2x 8mmx45mm linear ball bearings (two 2-packs) P/N 535226
4x 21mm bore bottom tapped clamping mount P/N 585660
2x XL belt mount A, P/N 585502
1x 10-tooth pinion pully, 1/4” ID, P/N 615376
1x 3/8”x24” timing belt, P/N B375-460XL
1x NEMA 23 stepper motor mount, P/N 555160
1x 1/4” x 1/2” OD flanged ball bearing 2-pack, P/N 535198
2x 4.5” aluminum channel, P/N 585444
Z-AXIS
3x 6” aluminum channels, P/N 585446
1x 12” lead screw P/N 634050
1x 8mm lead screw nut, P/N 545315
1x 8mm lead screw barrel nut, P/N 545314
1x 4mm to 8mm clamping shaft coupler, P/N 625082
2x 8mmx300mm shafting, P/N 634314
3x 8mmx45mm linear ball bearings (two 2-packs) P/N 535226
4x 8mm bore bottom tapped clamping mount, P/N 585634
