Goals:
*Design a custom power LED driver with a lot of functionality and ability for fast switching, with LiFi data transmission in mind.
*Pair it with a receiver that can read and interpret the LiFi signals.
*Demonstrate successful LiFi communication in a smarthome environment for multiple devices
More details:
- TX and RX are both arduino based
- TX LED driver is based on the TI LM3409
- TX PCB was fabbed by OshPark
- It works! (!!!!!)
The TI LM3409 is a DC-DC constant-current buck driver IC. This is a step down driver that can provide a constant current source to power LED(s). The circuit I designed around it is optimized for low ripple, fast switching capability, and current up to about 6A continuous.
Design specification as built:
Vin up to 20v
Vout 3v up to 17v (3v dropout max, 2v typical)
Output current up to 6A continuous (tested)
Less than 1% ripple (simulated and measured)
Clean switching up to 120kHz (measured)
Analog current adjust using ADJ pin (takes digital pwm inputs and filters using an RC)
Digital PWM/signal pin (turns off on pin HIGH)
Easily controllable using an arduino (or anything really...)
Schematic on KiCad:
PCB Layout on KiCad (BOM is included):
And a build video:
PSpice simulation circuit:
Recommend you use a heatsink on the bottom of the board, and on the LM3409 itself as pictured. Also recommended you use my 3D printed mount:
