To be used with...
08/30/2017 at 17:56 • 0 commentsThe following question came up in discussion, "Where is the Arduino supposed to plug into the chair?".
The DB9 (Serial port) adapter in this design is intended to be plugged into a power wheelchair that utilizes the RNET interface. Both the Input/Output module and LCD Omni module can be used. Both the I/O and Omni module have documentation on how to program the interface to allow button press input.
The chain should look like below
Computer -> Arduino -> DB9 Connector -> Power chair with RNET interface
Hopefully, that clears it up!
Initial Load
08/01/2017 at 20:06 • 0 commentsInitial upload of project contents. Keep in mind that this is a work in progress and detailed instructions/photographs will be added.
st0chastic
