Solar supercap floodsensor using Attiny45
Quick hack to make sure the basement stays dry.
After having some issues with water entering the basement without any form of warning i threw together this little puppy to do some monitoring for me. It is now almost 3 years ago an its still doing its job. I did a control measurement of the caps about a year ago in the wintertime and the voltage was just above 4 Volts. A control today revealed 4.4 volts half way into a cloudy summer day.
floodsensor_bms_attiny45.ino
For running off NiMH Cells
ino - 5.81 kB - 08/02/2017 at 11:50
Download
pitches.h
library
plain - 657.00 bytes - 08/02/2017 at 11:25
Download
floodsensor_noBMS_attiny45_supercap.ino
Yes there is a BMS version for running off NiMH cells. This is no that one.
ino - 5.92 kB - 08/02/2017 at 11:25
Download
  • 2 × 10F Supercaps, 2.7V
  • 1 × Attiny45 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × 5 ish volts solar panel.
  • 3 × 1 Mohm
  • 1 × Buzzer
