Setup & Update the ESP8266 - Getting Started Guide
Back to overview
Update the ESP8266 and connect it to Arduino IDE. A beginner tutorial for later use with Arduino and OpenHAB in my Home Automation series.
Hetal wrote 08/08/2019 at 10:13 point
I am working on setting up Mesh network using ESP 8266 module.
I have received the module and was going through the post for setting up the things.
I have a question,
Do I need to explicitly flash the firmware to my new module? or it will have firmware loaded and I can simply start working on interfacing it over UART.... use AT commands and configure the module?
I am confused because there are various posts on the similar lines but they talk about loading the firmware and all... However in my case I am not targeting any change  or programming in ESP8266.
I will connect the module with my MCU for configuring it and forming Mesh network.
