Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
restoring a FridenEC132 calculator
This is one device out of many to be restored for an upcoming early digital computing exhibition
jana°jana°
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4 comments
6 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
246
4
6
6
Team (1)
  • jana°jana°
Join this project's team
hardware
ongoing project
retro Computing early digital fridenec132
This project was created on 08/03/2017 and last updated 5 years ago.
Description
I am restoring my neighbors Friden132 and would like to learn how to a) discharge the capacitors, b)analyse electrical problems, c)resolder if necessary,.. etc. to try and at least power the machine up again. The CRT display was one of the first of its kind and displays up to 8 digits I found out.
Project Logs
Collapse
  • showing at vintage computer festival zurich
    jana° • 11/14/2017 at 11:50 • 0 comments
    me and the owner of the friden will be showing this and other devices at https://twitter.com/VCFe_CH
    http://www.vcfe.ch/doku.php?id=startseite
    Come to visit our stand if you are in the area!
    Jana° & Fritz
  • friden running!
    jana° • 08/20/2017 at 16:41 • 0 comments
    Ok so I had some help from Chris (also known as 'Tesla-Chris' !) who showed me to test for voltage leakage safely, brought along a gradual voltage meter and figured out where the power blockage/failure was. It turns out the only real problem ws in the mains power supply, and it is up and running on full 220V now,- with a slight leakage into the chassis (source still to be found..)
    Yay to Chris!! First device running, almost ready to be shown.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Oscarv wrote 11/14/2017 at 12:23 • point
The Computermuseum of the Uni Stuttgart is just repairing theirs. You might want to contact them if you need any information: http://computermuseum.informatik.uni-stuttgart.de/
jana° wrote 11/14/2017 at 12:42 • point
Oh great! -We have several, so will still need to get the others running, so thanks, always good to know there are others out there to collaborate with!
jana° wrote 08/03/2017 at 21:17 • point
thanks ted, given the age of them, I am expecting them to have to be replaced(?), but until I have learned how to safely 'discharge', I cant really diagnose even their condition. - I found a very useful blog about how the Friden is put together.. in case you are interested..
http://www.oldcalculatormuseum.com/friden132.html
Ted Yapo wrote 08/03/2017 at 15:43 • point
I'm not an expert, but my understanding is that you may have to re-form the capacitors as well.  Electrolytics slowly degrade over time, and you have to re-generate the oxide layer that forms the dielectric after long periods of disuse.  I'm not sure of a definitive source of information on the topic; I see some conflicting advice on-line.
A power supply solution for products requiring up to 600mA @ 5V from 2 x 55F Capacitors and small 5V Solar Panel
Project Owner Contributor
Solar Super-capacitor Power Supply
Darryl NormanDarryl Norman
AC regulated power supply 0-250V
AndyAndy
Voltage, current, power, frequency and energy.
Simple Power Meter on 100A.
EugeniEugeni
To make better/reliable version of existing 1000W zvs induction heater
A small, 2000W induction heater
lejnieksmartinslejnieksmartins
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "restoring a FridenEC132 calculator", please tell us the reason.
Send message
Remove Member
