Otto LC
Back to overview
A Laser cut chassis for the Otto DIY robot.
PatrĂ­cia wrote 04/12/2019 at 10:06 point
I did not understand the thickness of the wood. most of it is 3mm, but which part exactly is 5mm?
Florian Festi wrote 04/14/2019 at 20:01 point
The only pieces that are 5mm thick are the ones the servos in the body gets mounted on. They can be seen in the first picture of part 2 in the top left corner labeled "Servo Halter" which is German for servo mounting plates (literally "servo holders"). They need this thickness so the servos are flush with the bottom of the body.
Florian Festi wrote 10/25/2017 at 09:48 point
To switch between different programs.
Camilo Parra Palacio wrote 10/25/2017 at 04:21 point
what is the push button for?
