Simple Struts 2 Project
A project log for Struts 2 Project with the help of Tiles Framework
Simple Struts 2 Project with the help of Tiles Framework. It is one of the most important projects till date. There is so much modification
al-pachinoAl Pachino 08/05/2017 at 04:020 Comments
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE tiles-definitions PUBLIC
"-//Apache Software Foundation//DTD Tiles Configuration 2.1//EN"
<"http://tiles.apache.org/dtds/tiles-config_2_1.dtd">
<tiles-definitions>
<definition name="baseLayoutFtl" template="/tiles/layout.ftl">
<put-attribute name="title" value="Template" cascade="true"/>
<put-attribute name="header" value="/tiles/header.jsp"/>
<put-attribute name="menu" value="/tiles/menu.jsp"/>
<put-attribute name="body" value="/tiles/body.jsp"/>
<put-attribute name="footer" value="/tiles/footer.ftl"/>
</definition>
<definition name="hello4" extends="baseLayoutFtl" templateType="freemarker">
<put-attribute name="title" value="Hello 4" cascade="true"/>
<put-attribute name="body" value="/example/HelloWorld.jsp"/>
</definition>
</tiles-definitions>
