Menu problems while using serial console fixed
A project log for W1209 Data Logging Thermostat
The W1209 thermostat is cheap, but it's about time that it learns new tricks!
ThomasThomas 02/02/2019 at 23:060 Comments
Among other things, e.g. using the W1209 firmware for cooling, a problem with the menu has been fixed: transmitting characters quite often resulted in erroneous key inputs.
Now that has been fixed in the master branch. The discussion inIssue #22 is also quite interesting!
