A W1209 Software for Cooling Food with a Peltier Element
A project log for W1209 Data Logging Thermostat
The W1209 thermostat is cheap, but it's about time that it learns new tricks!
thomasThomas 02/03/2019 at 20:440 Comments
@paulcrawfordgm turned the W1209 Data Logging Thermostat into a cooling controller with a serial interface:
The project started here on HaD, continued with an STM8 eForth issue, and was completed in TG9541/W1209 issue #22.
Paul achieved the following:
The process of problem resolution and the Forth learning process worth reading!
