New version!
A project log for PD Buddy Wye
USB Type-C Power Delivery/2.0 data splitter
Clara HobbsClara Hobbs 05/05/2018 at 21:581 Comment
After the problems I had with the last batch of boards, I went back to the drawing board.  Well, back to hackaday.io anyway, where I found #Business Card Gamepad, which I figured might be a solution to my USB Type-C receptacle woes.  I found the relevant drawing in the USB Type-C spec and drew it as a KiCad footprint, which I then used to make a new version of the board.  Since it has to be 0.6 mm thick now, I couldn't order this board from OSH Park, so I went to Dirty PCBs instead.  The quality is quite good; the boards aren't dirty at all.
I originally considered gluing on thin pieces of single-sided copper-clad FR4 to act as shield pads.  I tried this on one board and found that it made no positive difference to functionality or robustness.  Securing them well enough was difficult, and excess glue caused some problems.  So, I ultimately decided to leave them out.
The new board works just as well as the older board revisions, and is much easier to build because I only have one connector to solder now.  I just listed them on Tindie, at a reduced price due to the lower material cost.  Hopefully this will be the end of the PD Buddy Wye supply problems!
diadatp wrote 05/18/2021 at 02:21 point
Those look really nice! Did you try with any other board thicknesses? Was it a snug fit?
