Boards arrived, one assembled
A project log for PD Buddy Wye
USB Type-C Power Delivery/2.0 data splitter
clara-hobbsClara Hobbs 08/28/2017 at 18:413 Comments
The PCBs arrived from @oshpark last week, and they're just great as usual.  Once again, the slight design rule violation for the USB Type-C receptacles wasn't a problem.
EDIT: I just realized that the boards were actually made a bit better than I expected!  There's a small radius (0.3 mm) at the inside corners where the Type-C plug mounts.  I understand that OSH Park's boards are usually milled out with a drill of radius 1.27 mm, so when I ordered the boards I expected to have to file these corners to make the connectors fit.  When it came time to assemble them, I didn't think about it and the connectors fit perfectly.  Now that I look closely, I see some evidence that those corners were milled with a smaller bit to match the board outline in the design.  So thank you OSH Park for the unexpectedly well made boards!
I assembled one of the boards today (I ordered the parts from Arrow on Tuesday.  They said they'd ship the same day, but the didn't ship until Friday.  Also, apparently "overnight shipping" means "next business day shipping"), and it works perfectly!  I'll assemble the others soon, and I'll list them on Tindie soon after that.
oshpark wrote 08/28/2017 at 21:42 point
Nice design.  Is the board our 2oz copper?  Kinda of looks like it the way the light reflects off the traces.
Clara Hobbs wrote 08/28/2017 at 22:55 point
Good catch!  The thicker copper is good for carrying the high current available with USB PD, but the board thickness is the essential thing here.  All of the edge-mount USB Type-C plugs I've found only fit on 0.8 mm PCBs.
oshpark wrote 08/28/2017 at 23:02 point
Nice, that is good to know :)
