Log03
A project log for S.A.M.I.R.A.
Synchronous All-Purpose Minimal Instruction Reckoning Apparatus
0xcafeaffe0xCAFEAFFE 11/30/2014 at 20:460 Comments
Second Stripboard almost complete! :) Transfering the circuit from breadboard to stripboard, wiring and soldering it takes an incredible amount of time. The new wiring/soldering techique slightly reduced that time, but it still took far longer than building the the CPU on breadboard! But im almost done now! All that is left to do is implement the STO instruction (3 control lines and 1 databus to connect) and IO operations, then add another multiplexer for reading out the accumulator through the front panel, connect the instruction status leds and pack everything into one case.
