Measuring Proxxon
A project log for 3D Moving Machinery
A plotter, light CNC router, laser engraver with exchangeable head. Mostly 3D printed
sufSUF 08/09/2017 at 14:290 Comments
I've a Proxxon Micromot drill. I'm planning to attach it to the plotter as replacement to the pen, to be able to do some light cuts.
For this I don't want to use it's original power supply unit. As the speed control is located in the power supply I wanted to know it's properties:
To measure this without disassembling, not looked like an easy task. The reason is that Proxxon uses a proprietary connector, what is not available on the market. So I measured the diameter of the pins and looks like with two 2.3mm drill bit I made it:
The measurements:
Without load:
At minimum speed:
At maximum speed:
It is a bit noisy to my taste and figured out that it runs at 100Hz and not really filtered.
Based on this I can design the new electronics into the plotter.
