Laying out the PCB
A project log for Ultrasonic Music Control
A small, driverless device that allows you to control your music with the wave of a hand.
lloyd3000Lloyd3000 • 08/23/2014 at 10:48•0 Comments
at the moment im working on the layout for the pcb. I decided to use smd components as you can see in this picture:
With these smd components i can get the hole thing fit below the HC-SR04 sensor. But still i need a double sided PCB, and ony have exposed pads as programming port...
But on the otherhand beacause the PCB is that small it will be very cheap to manufacture in china :)
