Strip-Board Design
A project log for One Bit CPUs
I have been exploring one bit CPUs. For the right application they may be worth knowing.
agpcooperagp.cooper 08/30/2017 at 13:340 Comments
Strip-Board Design
I made up a strip-board design for the 1 Bit CPU (2 bit memory version) using 74S571 PROMs (I  have a couple spare). The design uses two boards stack on each other.
Here is the top board:
Here is the bottom board:
Each board will take about 4 to 5 hours to assemble.
I seem to have forgotten the power supply? I will fix it tomorrow.
AlanX
