An example use case from the builder's perspective.
I turn on lights in the workshop. BL (Build Logger) speaks "Welcome" and I respond by speaking "Command start session". BL fully awakens, making Internet connections, opening its local web server, powering up all peripherals, and checking its SD card for consistency.
BL speaks "Remember Pictures". I grab my phone, tap the BL app, and snap a few shots of the bench, the pile of wood screws I just got from the store, and half opened Amazon box of goodies.
First things first, I caulk some cracks. That'll need time to dry. "Command one five start" and a 15 minute timer starts with an obliging "Beep" (the spoken word not the noise, because it's cooler).
Setting that aside, its time to solder. Holding a part in hand, "Command ef eee tee tee oh two two zero pinout". "Ground one drain two source three" comes back and that pesky FET's fate is sealed.
"Feed me". Ok, "Command record". "Hi again. Today, we're building the power supply for the next generation build logger. It's tricky because..." (spoiler removed) "... Command stop." Good, that'll really help with writing the next blog post.
"Command end session."
wes.faler
Also, it's gate, not ground.
