Day 3: Building the base
A project log for Building and improving the Thor+ robot arm
Building a 6-axis robot arm based on the AngelLM's Thor robot and the add-on's and improvements of dannyvandenheuvel.
SepioSepio 08/13/2017 at 09:340 Comments
Today I mounted the Ultratronics board in the big case and the stepper motor in the base. I printed the base with PETG. I have to change the printer settings because the filament was a little bit stringy.
