Day 21: Separating the Nextion display
A project log for Building and improving the Thor+ robot arm
Building a 6-axis robot arm based on the AngelLM's Thor robot and the add-on's and improvements of dannyvandenheuvel.
sepioSepio 12/23/2017 at 13:341 Comment
The Nextion was fitted in the base cover. This way it wasn't easy to read and it was also dangerous to operate.
After a question of Olaf I tried to tilt the display on the base plate. But that wasn't working because the robot arm could collide with it.
So I removed it from the base and made it like a tablet on a cable. This way its easier to keep in your hands and if the cable is long enough you can stay out of reach of the robot arm. It's also easier during programming because you don't have to remove the base cover to get to the SD card of the Nextion display. As a cable you can use a cut USB cable. (You need a shielded 4 wire cable).
I am currently printing this new design. If everything fits then I will make it downloadable below.
Below a rendered preview of the new design.
Olaf Baeyens wrote 12/23/2017 at 20:57 point
Interesting design. I think you could extend it so that it could be hooked at the base controller and taken off. This makes it easier to move the robot.
Interesting is that we now have a reusable display. You can use the same display for different robots.
