quick fix for the regulator
A project log for LAMEBOY - another ESP12 handheld
fully portable ESP12 project with battery charging and power muxing
davedarkodavedarko 09/12/2017 at 12:178 Comments
Since the AMS1117 regulator is not the best when it comes to the dropout voltage, I've made a little add on board, that will hopefully let me add the AP2112 regulator instead. They can be found on many adafruit boards, so I took that instead. I've ordered 12 boards, but the I'm still ashamed of what I "paid" and the board size :D
K.C. Lee wrote 09/15/2017 at 21:39 point
FYI AMS1117 does not like ceramic caps as output bulk cap as the part was designed before MLCC so it is ill prepared for low ESR.  They goes into oscillation.  See scope picture in ast part in my build log.  https://hackaday.io/project/11427-low-cost-ntsc-gaming-with-arm-cortex-m/log/37823-pcb-layoutbuild
You can either use a small series resistor (1R) with the cap or use tantalum/electrolytic or use AP2112 which works with ceramic caps.
davedarko wrote 09/15/2017 at 22:17 point
neat, didn't know that!
Arya wrote 09/13/2017 at 22:03 point
Hey, that's a nice idea - I might make some of those myself! If lucky, I'll find a way to panelize it properly on a 10x10 panel of 0.8mm PCB, too =)
davedarko wrote 10/24/2017 at 15:30 point
but what would you do with 1000 of these? :D
Arya wrote 10/24/2017 at 15:33 point
Send to starving kids in Africa, I guess =D The panel is almost full, it's just that this board is so small that there might be no place for adding tabs to it.
deʃhipu wrote 09/12/2017 at 21:40 point
We need to run a square centimeter contest, to show those freedom units lovers!
davedarko wrote 09/13/2017 at 07:30 point
my thoughts exactly! :D
Alex wrote 09/15/2017 at 20:48 point
good idea
