Deauther ordeal
A project log for LAMEBOY - another ESP12 handheld
fully portable ESP12 project with battery charging and power muxing
davedarkodavedarko 08/24/2020 at 19:120 Comments
I finally found my 2017 modified version of the deauther and added it to the download section. Use at own risk, don't come to me or Spacehuhn for advice. This is as is. Use it on your own tech only. Don't make people hate you because you want to "jam" your neighbors. Be nice and responsible.
Proud of the added "scan" for the button IO expander, as I've used different versions with different addresses over time.
