game concept idea
A project log for LAMEBOY - another ESP12 handheld
fully portable ESP12 project with battery charging and power muxing
davedarkodavedarko 08/28/2017 at 16:530 Comments
there's an invertDisplay function for the display, if you can find a version of the library that works on ESP8266 and you pipe in some lines of code... not the point now. The concept is inspired by stranger things, you have to get through a world and run into obstacles. You can only get through certain worlds by changing to the upside-down world (meaning invertDisplay) but there is that creature that closes in on you when you move, so you can't stay long on the other side.
