SSD1327 grayscale display board
A project log for LAMEBOY - another ESP12 handheld
fully portable ESP12 project with battery charging and power muxing
davedarkodavedarko 10/27/2017 at 23:432 Comments
So the SSD1327 grayscale display that I found on aliexpress.com is parallel only (8080 protocol). The chip itself is able to talk I2C and SPI as well, but the protocol select pins aren't broken out on the cable. Since I've ordered a display before I realized that and now that aisler has free shipping I designed a breakout anyway. Also on the board: a 15V step-up converter based on the MT3608 - that converter you get when you search for "12V step up" on eBay and sort by "price+shipping lowest first". Plus my new logo design :) I need a different micro controller for that.
deʃhipu wrote 10/28/2017 at 21:24 point
Ha! So you also have a mounting hole under the display!
davedarko wrote 10/28/2017 at 21:46 point
no I don't ;) I had more pins then display length :D I think it stops after D4.
