fixing rev2 board bug
A project log for LAMEBOY - another ESP12 handheld
fully portable ESP12 project with battery charging and power muxing
davedarkodavedarko 10/30/2017 at 22:022 Comments
so far I only know of @zakqwy ho ordered boards from that rev, but if there's anybody else out there, here's how to fix it, just connect the pads marked with an arrow with a bodge wire.
Arya wrote 10/30/2017 at 22:30 point
Hi! What's the reason for this bug? Just a brain fart, problem with switch pinout/function, or something else?
davedarko wrote 10/30/2017 at 22:42 point
that's the brain fart where the switch would give VCC to the enable pin of the regulator, to turn the regulator on so that there is VCC. Basically a chicken vs. egg problem :D
