Open Source FPGA Synthesis Tools (and CLI!)
A project log for TinyFPGA B-Series
Low-cost, open-source FPGA boards in a tiny form factor with built-in USB, SPI flash, LDO, and MEMS clock.
luke-valentyLuke Valenty 10/10/2017 at 06:420 Comments
I have pushed an update to the TinyFPGA B-Series GitHub repository with a template for the open source icestormFPGA synthesis flow.  Take a look at the new README for detailed instructions.
I've also added support for programming TinyFPGA B-series bitstreams using a command-line interface.  Take a look at the READ for instructions on using the command line interface.
