Web Interface test
A project log for ASC - Alexa Sprinkler Controller
Low cost, Alexa Enabled IoT 8 zone sprinkler controller based on the ESP8266
Ramsey GillRamsey Gill 08/20/2017 at 08:420 Comments
identified available GPIO on  Node MCU  ESP-12E
assignments are as follows
const int k1Pin = 5;  //ESP-12E D1 RELAYS 1-8
const int k2Pin = 4;  //ESP-12E D2
const int k3Pin = 2;  //ESP-12E D4
const int k4Pin = 12; //ESP-12E D6
const int k5Pin = 13; //ESP-12E D7
const int k6Pin = 16; //ESP-12E D8
const int k7Pin = 0;  //ESP-12E D3
const int k8Pin = 14; //ESP-12E D5
Wrote web interface and relay code, tested functionality and stability in brown out power conditions. Relay state seems to be stable when applying and removing system power/out of tolerance. Created quick video for web interface test. Attached screen capture of web UI
