aisler boards are here
A project log for I2C peripherals based on Attiny85 (mostly)
making noise over I2C, or send IR remotes or get an external controller, just stuff that is only helping if you don't have spare pins left
davedarkodavedarko 11/14/2017 at 21:474 Comments
Boards are here and although they have some mouse bites, they do fit nicely :) Already soldered one up and it works nicely! Now I only need to write an 8 player game to fully make use of them :D
Jarrett wrote 11/14/2017 at 23:56 point
Are you picking up the membrane keypads on AliExpress or something>
That's a good idea, never thought of doing that
davedarko wrote 11/15/2017 at 08:24 point
For now I have a little stock of used buttons and pads but since there are so many replacement pads and buttons on aliexpress... I thought why not :) A bit inspiration to actually do it came from the mintipi project, they use nintendo ds buttons, but I had the idea / need for a while.
deʃhipu wrote 11/14/2017 at 23:22 point
Is that a negative mousebite?
davedarko wrote 11/14/2017 at 23:35 point
oh wow, seems like it
