555 shaped triangle wave generator
A project log for Dalek / Cybermen voice changer
A simple ring-modulator circuit which can change your voice to sound like a Dalek or Cybermen from Doctor Who
sproketSproket 06/17/2021 at 14:460 Comments
Using this NE555 timer circuit with an RC wave shaping output stage, it appears I have the desired generated signal. Being powered with 9V and a negligible amount of current (singular milliamps) it is running at 27Hz with a 55% duty cycle. It couldn't be much better than that.
Next task is to find out what the signal looks like with an LM386 power-amp for the ring-modulator.
